And, as much as I avoid the old adage, "Replace the coil". You don't want to just throw one in "because", but now with the testing, wire to distributor disconnected, power on, power at one side of the coil, it's open on the primary side.
However, having seen corrosion issues before....check power on the wire lug in, then the coil stud where that power in wire bolts down. If good both places, check the stud on the output side to the distributor, then the lug.
Seen corrosion have it fail on one of those spots.
If power in okay at stud, power is making it to one side of the primary. If nothing on the other stud, it's open winding, one of the things that can happen when you leave the key on.
Get the correct coil for points, check to see if your y/m/m has a ballast resistor, so you get the correct coil for use with or without ballast resistor.
Dave
