MGB Stupidity.
So, do you know what the underlying issue was? The fix?
I will say, I have seen some real wiring idiocy....like a coil that doesn't work loading down a ballast....I have seen an extra wire to the power side of the coil...and followed it...and found it was feeding power to the fog light relays...or worse, a cooling fan relay.
Cooling fans can create some real shut down issues.
Turn the key off, and it keeps running...for a while.
Folks fight carbs, look for vacuum leaks...all because the fan motor becomes a generator when you power off, the blade acts as a flywheel, keeping the armature spinning...and you have enough power into the coil to keep it running for a while.
I got to the point I'd see how many wires were connected to the coil before doing anything else.
Dave
Dave, thats some scary wiring. Under my dash was what i thought to be a nightmare coming from the remnants of a radio. Apparently I have been shielded from true nightmares. Mickey, with your details I found that my ignorant points assembly had grounded everything in the distributor. That was compounded by My installation of an internally ballasted coil. Adding up for a very poor spark.
It all makes sense now. Glad you stuck with it; lots of folks would've thrown in the towel!
:cheers:
Mickey
