Okay...no power at the coil with key on. NOT the points or coil if you have no power on either coil primary wire.
If you have power to one side of the coil, disconnect the wire to the distributor and then, with it safely out of the way, key on, check for power on the end of that wire.
If you have power, you may have mis-assembled the points.
Seen it done.
If any of the bits are on the ground side of the insulator, it will act like the points are closed, and there will be no power out.
Now, do you have power on either of the coil primary wires?
If so, with the wire to the distributor removed (and you can do this at the distributor...only reason I have you check ay the end it to make sure that wire has not failed) do you have power at the end? Do you have power at the other end where it connects to the coil?
Report back and we'll go from there.
Dave
