TR4/4A stubborn lever shock link
Dash
Before I get too carried away pounding on the lever shock link to seperate it from the arm, wondering if the bolt on the link that attaches it to the arm is threaded into the arm? It seems more reasonable that it just slips through but I've whacked on it a few times and it's not budging so thought it a good idea to double check before I continue.. my intent is to replace the link bushings that I found in an obscure place in the moss catalogue but if anyone has done that and discovered it's not worth the hastle compared to just replacing the link, would greatly appreciate your input...
As always..Thanks
TR3driver
Great Pumpkin - R.I.P
The joint to the shock arm is a locking taper similar to a tie rod end.
I use a tie rod separator (which has a forcing screw).
Popeye
Bronze
Yep - taper. Mine required a combination of heat and strategic whacking on the side to get loose. Note, I did not care to keep the shock link as the rubber was history, and did not mind burning it some.
J General MG Stubborn spinner MG 1
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
S TR2/3/3A Stubborn door hinge screws in “A” Post Triumph 6
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
Gliderman8 Removing stubborn screw Restoration & Tools 22
Banjo TR6 springtime and stubborn TR6s Triumph 6
E TR2/3/3A stubborn TR3 turn signal wires Triumph 7
vping T-Series Stubborn Clutch hard line MG 2
2wrench Stubborn key in the crank Triumph 14
2wrench TR6 '74 TR6 Stubborn cam shaft Triumph 8
6 Stubborn rusted screws/bolts Austin Healey 4
RickB Need Tip to remove stubborn headlight trim rings MG 3
V Stubborn Bolts Restoration & Tools 14
Mark_Gibson Stubborn Screws on My TR-2 Windscreen Frame Triumph 3
R6MGS stubborn door locks MG 5
TNMGB Stubborn inline fuseholder... MG 6
CharlieCarpenter Stubborn Water Pump Austin Healey 2
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
Celtic 77 General MG Lever shock oil refiller MG 0
shadowfever Seat runner with lever Spridgets 2
Gliderman8 TR6 Lever shock noise Triumph 18
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
RJS General TR Lever Shock - HD Shock Valve Triumph 2
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
S Removing Overdrive Shaft Lever Pin Austin Healey 7
K Missing spring clutch release lever Other British Classifieds 1
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
D For sale. TR3A Bellcrank Pivot and lever. Triumph Classifieds 2
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
R TR2/3/3A Transmission Lever Assembly Triumph 9
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
J BN2 Shift Lever Bushing Replacement Austin Healey 6
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
AUSMHLY Lever Shock Oil Level Austin Healey 41
C TR2/3/3A Rotating shift lever Triumph 12
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
M Clutch fork lever Austin Healey 11
Graham H TR2/3/3A Gearshift lever chatter Triumph 7
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
M TR2/3/3A SU H Type Carberator Float Lever Adjustment Triumph 10
