Bob_Blue_BJ8
Er, Uhmm, Guys:
Just got back from the local ACE Hardware. Took the old machine screw and the NOS sender unit to ensure fit of new screws and cap washers. Turns out the old screws are 8-32. The NOS sender unit holes are also 8's - 10-32 screw won't fit. Ended up buying 10-32 stainless screws as the next step up. No luck with cap washers that will fit at the corners of the upper sender unit body. I may just try expanding the holes in the original copper washers and making liberal use of Hylomar.
Bob the Bewildered
Bob the Bewildered
Hi Guest!
