glutton for punishment-you might say that! Just the two of us.I used to drive my niece to K-garten in the 73 (she's now 27) so she will get that when we are done with it. Always wanted a spitfire-now that it's here we are not so sure! Oh, and forgot to mention the fiat(no scolding here)The intent is to keep the 73 and restore/sell off the rest towards an "A" or AH 3000-we know, wishful thinking! ANd it's hard to let them go.
yes-three coats of spray to both surfaces and let dry about 5 minutes in between them. The directions say you can wait up to 60 minutes. For some pieces the edges only were sprayed-pull them tight and work out the wrinkles, then apply downward pressure to make the bond.
Practice on a piece of remnant to a metal surface if you would feel more comfortable. It will also bond to the underpadding. The spray comes out of the can well-not like an areosol(sp)but you may want to mask off those areas not to be glued.
