OK, basic troubleshooting: If you are getting a strong spark at the cap center terminal, but it's not getting to the plugs, THAT'S THE PROBLEM!!! It makes no sense to look at point gap, fuel pump, or anything like that when the problem is elsewhere and staring you in the face. For some reason, the spark isn't getting from there to the plugs, so you need simply to figure out where it is getting lost. If none of the plugs are firing, the problem is most likely something common to all of them within that path. (I suppose it's possible that all the wires are bad, but not likely.) The only thing common to all of them is the cap and rotor. I suspect you have an incorrect cap or rotor, or perhaps, as was suggested, something is just not made right. It's not unusual in the aftermarket junk we're forced to use.
Never, never, NEVER assume that a part is OK just because it's new. I did some measuring of a couple of distributor caps at one point, and found a significant difference in the height from the surface where the cap mounts on the distributor to the contacts. Very disturbing! So, this isn't just a theoretical idea. I suspect that the many stories of "bad rotors" are just rotors that aren't made to the right dimensions.
Hi Guest!
. . . I'm up for that!!! . . .
