Stereo Memory Wire/Speakers
Cain
I installed a new stereo in my TR6 last night. When it says to hook the memory wire (yellow wire) directly to the battery - do you physically hook it directly to the battery? Or can I splice it into a wire that always has power - like the wire to the headlight switch? Besides the wire to the headlight switch - what's another wire nearby that is always hot?
Also, where do most of you put rear speakers? I thought about either (1) building some small boxes to mount behind the seats on the rear paneling or (2) mounting them behind the paneling behind the seats (adjacent to the fuel tank). My problem with option #2 is I don't really care to cut holes in the rear paneling to actually hear the speakers.
I guess another option would be to just mount all four speakers in front - two in the kidney panels and two in the kick panels.
Mickey Richaud
Re: Stereo Memory Wire
Any wire that remains "hot" should be fine, though you may want to put an inline fuse in, just for safety's sake.
Mickey
danmas
Hook it to any convenient purple wire - they are hot all the time and they are fused.
Adrio
I second the question about speaker placement. Have people had any luck with speakers in the back of these TR4/250/6 cars. I am toying with the idea of installing a radio/CD player, but wonder if the volume has to be so high in order to hear that the whole thing is not worth the effort. What have you folks found about this.
machinemd
In my TR6 I have a Pioneer 200watt cd/tuner , which is normal these days. I made kidney pads for Sony 5 1/4" speakers up front and made boxes for Sony 6 1/2" speakers on the rear shelf. The surprising part tho is the sound from the front speakers just gets lost with the top down. The rears are where the real sound is. I didn't feel that there was decent space behind the rear panel for speakers and they'de have to mount so low you lose that storage space or block the speakers. Even the unzipped rear window blocks them. So I made 1/4" hot glued masonite boxes lined them with contact cemented felt rug padding, a 1" pvc bass tube again hot glued, and contact cemented black rug on outside, and quick disconnect plugs. They're movable, removable, look and sound great.
Steve
J Dynamo and Stereo Other British Cars 1
Gliderman8 TR6 Stereo radio? Triumph 4
M Stereo Speakers Spridgets 18
Jer Tips on Installing Stereo Spridgets 14
John_Mc Mazda Stereo woes... Other Cars 2
bugedd Stereo in the bugeye Spridgets 11
1 MGB What stereo fits in our MGB's? MG 14
JPSmit stereo question Spridgets 1
RickB Got stereo for Birthday -where to put front spkrs? Spridgets 7
B New stereo for my Midget Spridgets 19
Camshaft Stereo & Cupholder Install, Camshaft Style MG 13
TNMGB Stereo installation question...again... MG 39
MadRiver Good and inexpensive stereo recommendation? Triumph 13
Jerseygirl Spitfire Spitfire stereo question Triumph 22
M MGB Modern stereo units for MGB's? Any advice? MG 19
Alfasudcrazy Radiomobile stereo 8 removal Jaguar 3
TNMGB Installing new stereo MG 10
Webb Sledge Stereo and a Headlight Triumph 14
S JAGUAR SOVEREIGN stereo Jaguar 3
J positive gound stereo install Triumph 10
E 1996 vanden plas stereo questions??? Jaguar 1
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
Bayless Memory block Spridgets 3
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
Rut Help a bad memory out... Spridgets 6
GTP1960 Drive down memory road. Other Cars 14
NutmegCT Memory test Other Cars 9
F Sharing Memory Lane in an Austin Healey Austin Healey 7
PAUL161 Happy/Sad Memory, My Old Austin Other British Cars 2
Nelson Senior memory aid Spridgets 12
Morris Refresh my memory... Spridgets 5
K Memory Refresh:What oil to use after break-in? Triumph 1
K SU Mix Adjust Memory Refresh Triumph 7
10musketeer Clutch Peddle Box- Refresh my memory Spridgets 7
B A sad memory of a fellow Midget Owner. Spridgets 5
jlaird Someone jog my old memory Spridgets 20
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
SNClocks Electrical Wire Lug Spridgets 2
R Wire Wheel Fit Austin Healey 10
