Steering Rod Installation
Walter74
Hello fellow enthusiasts,
I am rebuilding the steering box of my BJ7. With the installation of the inner ball bearing, I encountered problems. Somehow the ball bearing seems to be crooked and does not touch the outer race. Any suggestion on how to install the ball bearing correctly? I was thinking to remove the felt bushing to create more play, but how can I reinstall that after the steering rod is in?
Thanks in advance!
Walter
If the box is in the car, use a little grease to hold the caged bearings in place when you insert the shaft. If it's on the bench, if you can find a way to hold the shaft upright, and get to the box with, say, a ladder (though I haven't tried this).
red57
Make sure the upper/outer race is in squarely and fully seated then, as Bob suggested, use some grease to stick the ball bearing cage and balls onto the inner race on the upper end of the worm and then carefully insert the shaft & worm with caged balls into the box. Once the worm and upper bearings are in place you can install the lower balls and race. I have found that if you stick the balls and cage into the upper/outer race inside the box first, it can be tough to get the inner/lower race to go in.
As you add/remove shims on the end plate to set the end float, you have to be careful the shaft doesn't slide out and miss-align the upper set of balls again forcing you to start over (frustrating job as it is without having to start over).
Whatever you do, don't use force as it is possible to damage the balls and races and, as you probably have noticed the inner races are ground into the worm and aren't replaceable.
Dave
Walter74
Walter74
Ok guys, thanks for the answers. Do you install the shaft with the felt bushing in place or first install the shaft and then the felt bushing?
red57
I've done it both ways. If the felt bushing is used and slightly compacted, it's fairly easy to push in after the shaft is installed, but if the felt is new and un-compressed, it can be a bit if a struggle. If the felt is new felt, I think it's easier to install it first and then the shaft.
Another thing to consider if the felt is new, it causes a surprising amount of drag when turning the shaft. I think it's a little easier to check the bearing preload and determine what shims you need without the drag of the felt in place - just food for thought.
Dave
steveg
I ruined the rear bearing and race by doing as described above. Bought a new worm from DW. In the process of rebuilding, I installed this centering bush made from a piece of 1" EMT with a tapered edge. This causes the bearing to automatically center on the race, thus preventing damage.
oxford steering cross rod Austin Healey 13
KVH TR4/4A TR4 Steering Rod Splines Triumph 2
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
Monark192 Removing Tie Rod End From Steering Arm Spridgets 11
ChrisS Steering Rack Outer Tie Rod End Size Spridgets 3
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
MikeAH100M BN2 Tight Steering Austin Healey 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
