Steering Rod Installation
Walter74
Hello fellow enthusiasts,
I am rebuilding the steering box of my BJ7. With the installation of the inner ball bearing, I encountered problems. Somehow the ball bearing seems to be crooked and does not touch the outer race. Any suggestion on how to install the ball bearing correctly? I was thinking to remove the felt bushing to create more play, but how can I reinstall that after the steering rod is in?
Thanks in advance!
Walter
If the box is in the car, use a little grease to hold the caged bearings in place when you insert the shaft. If it's on the bench, if you can find a way to hold the shaft upright, and get to the box with, say, a ladder (though I haven't tried this).
red57
Make sure the upper/outer race is in squarely and fully seated then, as Bob suggested, use some grease to stick the ball bearing cage and balls onto the inner race on the upper end of the worm and then carefully insert the shaft & worm with caged balls into the box. Once the worm and upper bearings are in place you can install the lower balls and race. I have found that if you stick the balls and cage into the upper/outer race inside the box first, it can be tough to get the inner/lower race to go in.
As you add/remove shims on the end plate to set the end float, you have to be careful the shaft doesn't slide out and miss-align the upper set of balls again forcing you to start over (frustrating job as it is without having to start over).
Whatever you do, don't use force as it is possible to damage the balls and races and, as you probably have noticed the inner races are ground into the worm and aren't replaceable.
Dave
Walter74
Ok guys, thanks for the answers. Do you install the shaft with the felt bushing in place or first install the shaft and then the felt bushing?
red57
I've done it both ways. If the felt bushing is used and slightly compacted, it's fairly easy to push in after the shaft is installed, but if the felt is new and un-compressed, it can be a bit if a struggle. If the felt is new felt, I think it's easier to install it first and then the shaft.
Another thing to consider if the felt is new, it causes a surprising amount of drag when turning the shaft. I think it's a little easier to check the bearing preload and determine what shims you need without the drag of the felt in place - just food for thought.
Dave
steveg
I ruined the rear bearing and race by doing as described above. Bought a new worm from DW. In the process of rebuilding, I installed this centering bush made from a piece of 1" EMT with a tapered edge. This causes the bearing to automatically center on the race, thus preventing damage.
oxford steering cross rod Austin Healey 13
KVH TR4/4A TR4 Steering Rod Splines Triumph 2
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
Monark192 Removing Tie Rod End From Steering Arm Spridgets 11
ChrisS Steering Rack Outer Tie Rod End Size Spridgets 3
F TR2/3/3A Steering parts Triumph 16
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
R TR2/3/3A Replace wiring harness in steering column Triumph 15
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
T Wanted. 14"-16" Les Leston or Carlotti wood steering wheel Other British Classifieds 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 16
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
Walter74 Steering Box End Play Austin Healey 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
K TR2/3/3A Steering Issue? Triumph 23
J Steering Wheel Repair Austin Healey 32
R TR2/3/3A Wiring from the steering column Triumph 7
Walter74 Adjustable steering wheel removal Austin Healey 4
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
M TR5/TR250 Steering Rack Fitment/Geometry Theory Assistance Required. Triumph 1
J Experience with High Ratio Steering Box? Austin Healey 15
Jayplum TR2/3/3A Steering Box end play Triumph 6
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
D TR6 Replacing Horn insert in steering column Triumph 11
B Excessively Tight Steering Austin Healey 19
M TR6 Power Steering Rack & Pinion. Triumph 0
C Steering Rack Spridgets 17
M TR6 Replacement Steering Rack ? Triumph 7
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
D TR2/3/3A Shaking in steering wheel above 50 mph. Triumph 19
G Steering wheel offset Austin Healey 10
D Steering Wheel Repair Austin Healey 2
M TR2/3/3A Steering Lock to Lock Measurement Triumph 3
steveg TR6 Steering boot clamp wire - why? Triumph 2
Michael Oritt Steering box lube Austin Healey 22
K For Sale TR3A Steering wheel Triumph Classifieds 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 2
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
Exotexs For Sale 1968 MG-B steering wheel and handbooks MG Classifieds 0
S Power Steering Austin Healey 3
L TR2/3/3A Upper steering column bushing Triumph 3
DerekJ Original steering wheels Austin Healey 1
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
K TR2/3/3A The steering box again? Triumph 9
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
E TR6 Steering Triumph 3
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
