found the problem. I disconnected the steering, replaced the gaiters, filled the rack with Corn Head Grease and discovered the left kingpin was extremely stiff. I loosened the top nut and voila...the kingpin swiveled again. so....apparently when I had pulled the upper trunion attachment off to remove the offset Delrin bushings (and re-install the Prothane bushings) a couple of weeks ago, I must have lost a thrust washer shim. without knowing that and shoving the trunion pin in, then tightening the kingpin nut, i never noticed any drag because the steering link was still hooked up when I did that job, so I never bothered checking for proper swivel axle operation. now I know not to do that again! Murphy's law I suppose.
anyway thanks for all the replies!
mark
mark
