Hello All,
I've seen a number of ways the steering column grommets have been installed, sometimes trimmed. The clamp onto the column itself is clear. Should there also be a hole in the firewall above the column where the top base of the grommet is screwed in? Also, on my car, there is a band of metal along the side of the firewall protrusion. I have read that the side of the grommet gets bent around the edge and stuffed in there. Is that so, and if so, should it also be attached by a screw on the side? Any available photos would be very much appreciated.
Regards, Walter
Regards, Walter
