I had posted earlier stating that my TR3 starter wouldn't engage (just made noise) and I pulled it out to inspect the "guts" as some of you suggested. Before I opened it I tested it outside the car.. It spun the motor but the gear did not push its way out of the original position. I then opened it, cleaned, push pulled, oiled and then cleaned and dried off any excess lubricant. I could not see anything really obvious. I put everything back together and tested it again-- The bendix (or what ever it's called by our British friends) now only came half way to its destination. Because I didn't know what was wrong I took it to a LBC mechanic I had used before and explained the symptoms. Today I got a call to say the starter works fine and did I want to pick it up... $150 and change for rebuilding the starter. The mechanic wasn't there when to answer my questions but another mechanic said the starter was too weak to engage the bendix properly. Oh and also said, "you know, those things aren't available any more" over and over..
So-- is this an acceptable explanation? Price fair? (new brushes, turn armature, etc) but didn't touch bendix. It also seems like the TR4 starter was the sub in the MOSS catalog-- right?
