Offenhauser 5165 - Offenhauser 360 Degree Single Quad Low-Rise Intake Manifold is designed for 215 Buicks AND Rovers and such.
Summit has them.
Also, Edelbrock 21981 - Edelbrock Performer Intake Manifold may be of interst...low riser would keep the 'burettor low...
The one's I have seen are standard Stag intakes that have had the top machined down and a 4 barrel adapter plate with a 7 degree angle welded on top. Also seen ones that use a weber downdraft.
Hmm....I mis-spoke, true enough. Was thinking 215 Buick.
Having trouble seeing photos clearly today. This 28 and snow has given me a migraine that won't quit.
The notes I have indicate that Tony Fox in Canada tonyfox@sympatico.ca, sells a 4bbl intake manifold for the Stag motor (and not the BOP/Rover motor). Tony Hart in the UK https://www.hartrace.demon.co.uk/ sells an adapter plate to fit a Holley to the original manifold, but I hear it's still kind of restrictive.
Actually Randall, Tony Fox sells the adapter plate that fits on a stock Triumph Stag intake manifold. It is set up for a 390 CFM Holley. Last I checked, Tony Fox adapter is $135.
The Tony Fox unit is a bit less cost than the Tony Hart (HRS) unit and has some design changes from HRS design.
