sim
Installing a new electronic flasher made by CEC Ef33 has 3 prongs . I can get it to work but when the ignition switch is turned on , the dash light flashes when the switch is in the off position. Flick switch to right and right lights blink and dash light still blinking. The same when switch is to left . Left lights blink and dash light blinks. Put switch in center position dash light still blinking but turn lights are off. I pulled the switch and messed with different wire placement. now I was lost so i pulled all wires off to find the hot one. When ignition switch was turned on the dash turn light still blinked. I pulled the green wire off the flasher unit , put the wires back on the switch, turned on the ignition switch and the flasher unit still worked. Just no dash light. So here is my thought. Cut the green wire at the dash light and then add a new wire to the flasher unit . it would connect to the L and R legs. So when the turn lights blink so will the dash light. Think this will work? As the only time the F unit gets power is when the dash switch is switched L or R when ignition switch is on.
A solid state unit driven by + ground then all bets are off. Without knowing exactly what's inside, it's near impossible to guess why it acts strange, but not surprising.
