Foghat73
I'd like to ask a related question to this thread...
Is it possible to rebuild the shock absorbers?, driver side looks good and the other may have been leaking and is coated with oil.
Also, I had to end up using a slightly modified coil compressor to get the coil out, the bolt in the wishbone frame around the coil spring pan closest to the wheel was rusted and fused together and wouldn't budge enough to widen the frame to rotate and drop the coil pan, it worked and all's good.
