Spridget Triple Master Setup
blkcorvair
Well My Xmas presents arrived and I snuck them out early. (minus one master cylinder that is wrapped up under my sister in laws tree.) Two will work for fitting it though. Heres what I got. Alot of work to get those pedals to line up even with the stock accelerator pedal height. Question though. Can I cut (shorten) the master cylinder push rod by like 3/4". This would allow me to set the pedal faces even with the acc. pedal.
Still have to add the sheet metal, and weld everyuthing in place...
JerryB
You can shorten the pushrods but what you want is at the clevis that screws onto the rod, to describe an arc the same distance front-center-rear on the clevis pin or close to the same distance. In other words you dont want goofy angles on the rods.
Leave enough threads that go thru the pedal arm up top but not so long as so they dont jam up on the back of the pedal arm.
Dont use that o.e. brake blok.
if you have drum rears use a 10# RPV valve in the rear line just out of the master. disc rear no RPV.
Is that ignition coil oil filled ??
B
blkcorvair
Got the RPV 10# jes came today.
The OE brake block you describe. Do you meen the splitter with the waring sensor. (Bad to keep this?)
Yes that is a crane oil. filled coil came with the ignition I had.
B
blkcorvair
Getting closer. Made the mounting points. Decided to bolt it in rather than weld in and boxed in the masters. Need to make a aluminum cover plate for the pedal assy's and Im good to go. Hopefully Ill get it painted tomorrow.
B
blkcorvair
I have gotten it all installed. No leaks. Cross youre fingers!!! Took it out for a quick ride. Pedal is not as positive as Id like but I can lock the front wheels with a bit of effort. Did a shoddy bleeding job. But I was in a bit of a rush. Tommorws another day. Im sure I have to give it some more rear bias, I really gotta re-wire and move this coil outta the way so it makes my life quicker getting in and out of the adjustment box.
P For Sale Spridget in a junk yard Spridgets Classified 1
JPSmit Lovely little Spridget video Spridgets 4
R Help With Spridget Speedometers Spridgets 4
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
shadowfever 65-69 Spridget seat Diaphragms Spridgets 5
shadowfever Single SU on Spridget Spridgets 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
shadowfever Wanted WTB Spridget seats. Spridgets Classified 0
Editor_Reid Happy (Spridget) Christmas Spridgets 0
D Spridget Modifications Spridgets 12
S Classic Motorsports : 10 Common Spridget Mistakes Spridgets 1
M 68 Spridget Spridgets 6
B Spridget with a Tilton Race Clutch Racing 1
M Spridget wont start Spridgets 50
S Spridget Mountain Driving Tour : Mid-Atlantic Spridgets 8
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
N Misc Spridget parts Spridgets Classified 0
N Spridget sheet metal Spridgets Classified 0
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
T Roy Orbison had a Spridget! Spridgets 2
I Wanted emergency brake rods from later Spridget Spridgets Classified 0
S For Sale Spridget Parts Garagea Clearance Spridgets Classified 5
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
Jer For Sale Assorted Spridget Parts Spridgets Classified 0
JPSmit Spridget thread question FORUM Navigation Questions 2
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
T Smart Car Seats in a Spridget? Spridgets 8
histerical Wanted WTB Set of Later Spridget Rear Brake Backing Plates Spridgets Classified 0
6 Spridget Radio/Speaker Case Spridgets 4
Jim_Gruber Free Spridget Windscreen available - Dayton OH Spridgets 3
FredApplerot For Sale Pace Setter muffler for 1964-74 Spridget - Brand New Spridgets Classified 5
M Hauling a Spridget - Proper tie down technique? Spridgets 15
M Period Spridget articles Spridgets 5
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
HealeyRick Ro-Spridget AutoX Spridgets 4
T Question regars 'frame assembly-hood' for various spridget models Spridgets 7
Rut Interesting non Spridget Spridgets 3
Michael Oritt Spridget Differential Carrier--early versus late question Spridgets 1
Jim_Gruber A Quality Piece of Kit for Bugsy IV - Creative Spridget Rear Disk Brackets Spridgets 8
Jim_Gruber Replacing Spridget Coolant Spridgets 21
Jim_Gruber Adjusting Spridget Doors Spridgets 4
gfholl Spridget on a stick Spridgets 0
drooartz 400 mile road trip in the 4-door Spridget Spridgets 11
drooartz The family Spridget Spridgets 10
N 60's Spridget paint? Spridgets 20
drooartz Up-date on the 4-door Spridget [Morris Minor] Spridgets 12
Trevor Jessie Any of you Spridget guys coming to MG2016 in June? Spridgets 3
R Spridget Starter Spridgets 4
T Harley-Davidson mufflers on a Spridget Spridgets 14
