Hi Guys,
I bought a pair of swing axles and could not separate so I had my mechanic take care of disassembly and reassembly. I now find out the new axles were the wrong ones and have to do this all over again. Since this was recently assembled I figure I would save the money and do it myself but I’m running into and issue. I don’t want to damage the new bearings so I thought I better ask before I continue. I was able to remove the hub without much effort but the rest of the assembly is still on the axle, I tapped it a few times with a hammer to try to loosen but it hasn’t budged, is there anything that needs to be removed or is it a matter of being persistent and using a bigger hammer and eventually everything else will come off.
Thanks, for your help,
Rick
Rick
