I'm putting a 1500 in a 74 spit that had a 1300 in it from the DPO. The two trannies seem to be the same.... Are they? or will I have to swap Transmissions as well?
All should be the same if the first motion shafts are fine spline. If one is fine and the other coarse then you have a small problem. If the crankshaft bolts in the 1300 are 3/8 SAE then you have more of a problem.
They should be the same. A quick "eyeball" of the input shafts and output flanges would confirm. Both should be the same size: 10 splines on the input shafts, and make sure the output flanges are the same "PCD". Checking gearbox serial numbers can also help: both should likely be prefixed with "FH" letters.
If the input shafts have different spines, you can still use either transmission with the correct clutch and flywheel. I converted my Mk I Spitfire to a 1500 OD transmission.
