They should be the same. A quick "eyeball" of the input shafts and output flanges would confirm. Both should be the same size: 10 splines on the input shafts, and make sure the output flanges are the same "PCD". Checking gearbox serial numbers can also help: both should likely be prefixed with "FH" letters.
