Spitfire Spitfire 1500 distributor end float?
Norton47
Does a Spitfire 1500 engine need the distributor end float set up the same way as a TR6?
This car has a cork gasket under the distributor pedestal and I don't think that looks right. What is it suppose to be? Paper like a TR6?
If end float is required, what is the value?
Anyone have a 1975 Spitfire manual they no longer need?
Thanks
70herald
I don't have a 1500 manual, but it should be the same as the older engines. end float should be between 0.002" and 0.007"
The normal spacers are paper type gaskets, not cork.
guzzul
Yes, it does need to be set up more or less the same way. The BL manual specifies an end float of .005" (plus or minus .0002") between distributor pedestal and drive gear.
Maybe a cork gasket is ok, depending on the clearance required, but it sounds like it might be a little thick. Usually they would be paper.
Send me a PM and I can scan and send you the setup instruction from the BL manual.
G Spitfire Spitfire 1500 differential whining Triumph 6
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
B Spitfire Advice on swapping to J Type OD with 1500 engine in 69 Spitfire Triumph 13
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
F Spitfire Spitfire 1500 Dash Lights Triumph 1
W Spitfire Spitfire 1500 Steering Column Triumph 3
dklawson Spitfire Clutch Kit Preference - 1500 Spitfire Triumph 3
Anthony_S Spitfire Spitfire 1500 for sale in my area Triumph 1
S Spitfire Is a 1973 spitfire a 1500 or a mark IV? Triumph 7
dklawson Spitfire Spitfire MkIV/1500 - Factory Front Spoiler? Triumph 3
dklawson Spitfire Spitfire MkIV/1500 Body Gaps - Bonnet to Bumper Triumph 2
F Spitfire Spitfire 1500 Door Handle Removal Triumph 1
F Spitfire SUs On a Spitfire 1500 Triumph 14
Scott_Hower Spitfire Late Spitfire 1500 CV driveshaft Triumph 3
F Spitfire Spitfire 1500 - Stromberg CD 150 Question Triumph 9
F Spitfire 1500 Spitfire Windshield Glass, Gasket and Install Triumph 12
Don_R Spitfire Spitfire MKIV/1500 parts book Triumph 2
F Spitfire Spitfire 1500 Electrical Question?????? Triumph 4
F Spitfire 77 Spitfire 1500 Questions Triumph 3
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
mikecyc72usa Spitfire First Autocross in my Spitfire 1500 Triumph 29
F Spitfire 1500 Spitfire Engine Noise Triumph 14
A Spitfire TRIUMPH SPITFIRE MKIV 1500 Triumph 2
K Spitfire 60’s spitfire body swapped onto a 1500 cassis Triumph 3
M Spitfire Spitfire 1500 OD transmission Triumph 9
A Spitfire Triumph Spitfire 1500 Triumph 8
K Spitfire Spitfire Mk IV tonneau =Spitfire 1500 tonneau? Triumph 2
dklawson Spitfire Crank Endfloat and Oil Pumps - Spitfire 1500 Triumph 9
bowiderberg Spitfire Whitworth on a Spitfire 1500? Triumph 8
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
pjsmetana Spitfire Spitfire 1500 TC Triumph 2
frankenstang57 Spitfire Spitfire 1500 fast road cam question Triumph 4
1965_MGB Spitfire Junkyard Find, Spitfire 1500 I think Triumph 6
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
