regularman
I got some things done and got bored and ended up fooling with the idle jets in the DGV on the midget. It had a small stutter going from idle to easing open the throttle. I drilled out the primary idle jet and then adjusted it all in and the stutter is all gone now. I took it down some winding roads and opened it up a bit and it was a blast. Ran it up to 80mph on the interstate and it did really well. I will wait until tomorrow to check the water and see if it is low or whatever. It was 36 degrees outside so overheating was not a problem. This was of course a top up ride. Nice to have heat. My other play toy is a motorcycle and I took a ride on it but it was not very long. Oh, and a word to the wise, check your tire pressures for winter. My midget was too wiggly and I need to air up the tires more.
