AUSMHLY
Hello,
BJ8 with overdrive.
Recently rebuild engine so I sent the speedometer out to have the odometer zeroed out. Informed them it works fine and I only need the odometer rolled back. They said they will not do that unless they rebuild the unit.
Not sure if it matters, but when I got the speedo back the first time, the needle did not move, but the odometer did.
I sent it back and they fixed that...sort of ?
When I got it back the second time I found if fluctuates/bounces between the range of 0 to 30-40 then smooths out.
I replaced the original UK cable with a new moss cable from Taiwan, no improvement. Both cables (new/old), the flange to the end of the shaft that goes into the speedometer is 3/8". I have it finger tight.
I replaced the original angle drive brass/copper sleeve, with a Moss which has a silver sleeve. No improvement. I have both the screw collar to the tranny and screw collar to cable finger tight. The tranny adapter is taught enough so with some finger force I can change angle.
I've removed the speedometer from the dash and had it on my lap when driving, so the cable had a smooth arc, no difference.
It fluctuates/bounces back and forth about 5mph on the gauge. Example, 0-5, then 5-10, 10-15 etc until I reach about 30-40 mph, then it's smooth.
Is that normal, some fluctuation at low mph's?
Could the pinion assembly be the cause?
Is it the speedometer and need to send it back a third time? I did notice when I grab the cable about 2" out the back of the speedometer and move it side to side it moves the speedometer face. Maybe normal, but I'm focused now on everything.
Thank you in advance.
BJ8 with overdrive.
