'69 GT. Replacing the speedo angle drive (on gearbox), and am a bit confused by the Moss/VB exploded views. Moss cautions to install a washer "beteen the angle drive and gearbox to prevent excessive end pressure on the pinion gear". Makes sense, but VB says "be sure to install a copper washer between the cable and angle drive. Neither mentions both, and the shop manual is silent on the subject. Since I know these are prone to failure, I thought someone might be able to clear this up for me. Where do I need to install washers?
Thanks
Thanks
