Sourcing Grade 8 bolts.....
T
TR6BILL
I got my 12 prop shaft bolts and 12 Cleveloc all-metal locking nuts in for my diff today. OUCH! 40+ bucks! If you want to dance, ya gotta pay the band.
DNK
BobbyD said:
Don.... I'm sure they are of better quality. My whole point in this thread is that way too many people replace very critical bolts with Grade 8 when they should be using "close tolerance" or "precision ground" bolts.
Bobby- No pro blemo man.
You know, I should practice what I preach. When I redid my shafts I hadn't discovered this place yet. I know I just got stinkin ordinary grade 8's in there.
Probably not even the right shouldered ones.
T
TR6BILL
BobbyD said:
How did those Cleveloc nuts go on compared to nyloc? Were they harder to get on or about the same?
The Cleveloc nut is an all-metal locking nut that requires more torque to seat, not that that matters - you are wrenching them on anyway. But you know and feel the difference. Never was a fan of Nyloc nuts in a high stress application. Technically, Clevelocs are reusable. I always replace them when I take them down though. A little red Loctite won't hurt either.
TomMull Parts sourcing from the UK [5/18/2020]. Restoration & Tools 12
steveg Sourcing Custom Caliper Hoses Austin Healey 2
brgrmyster GT6 Sourcing the adjustable control rod 69-70 GT6+ Triumph 1
T Sourcing a correct engine for a '71 XKE Jaguar 14
J Sourcing Roller Rockers Austin Healey 23
RandallRK Door latch striker nut sourcing- 100-4 Austin Healey 3
T sourcing linkage ball/sockets Austin Healey 13
drooartz Sourcing snaps for folding top frame MG 9
JodyFKerr Stag Sourcing a Stag Type 35 automatic Triumph 4
J Bugeye grille sourcing? Spridgets 10
brgrmyster TR6 Sourcing TR6 Kangol Reflex seatbelts Triumph 6
I Sourcing Core plugs in UK & securing windscreen Austin Healey 11
Rut Grade 9 bolts Spridgets 6
Rut MGB Grade 9 bolts MG 4
Rut TR4/4A Grade 9 bolts Triumph 6
sim 58 sprite suspension up grade or not Spridgets 25
KVH Grade 8 Bolts Triumph 7
MadRiver Multi-grade oil in gearbox? Austin Healey 2
I Suggestions for drilling a hole in a grade 8 bolt? Triumph 24
I Internet source for grade 8 bolts? Triumph 12
19_again grade 8 nuts on ?grade studs MG 14
I rear axle to differential flange bolt grade? Triumph 8
Tinkerman Grade 5 or Grade 8? Triumph 13
hondo402000 alternator up grade and smoking dash Triumph 19
W What grade of gas/petrol ?? MG 17
A TR6 Up-grade to 1/2" lug bolt, which ones??[tr6] Triumph 7
M TR4/4A OE tr2,tr3,tr4 aircleaner up-grade!! Triumph 4
hondo402000 TR6 alternator up grade for 71 TR6, what works Triumph 8
V New Grade 12.9 Socket Head Bolts Triumph 2
I Best bolt grade for Triumphs Triumph 20
R what grade oil Austin Healey 2
EinsteinsDad Grade markings on British Whitworth Fasteners Restoration & Tools 4
T Where to buy Factory Grade Paint? Triumph 6
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
shadowfever Midget seat nuts and bolts Spridgets 2
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
D ARP big end bolts. Spridgets 7
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
W Generator and Starter Long Bolts Spridgets 0
G HD8 Carb Banjo Bolts Austin Healey 2
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
M Tranny Mount Bolts Spridgets 3
M TR2/3/3A oil pan bolts Triumph 16
AUSMHLY BJ8 Dowel Bolts Austin Healey 35
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
B McMaster Carr for bolts and fasteners Spridgets 8
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
charlie74 TR6 Bearing cap bolts Triumph 8
