TR6 Source for TR6 pressure switch [pdwa] rebuild kit?
SpannerMan
Dear all,
Tonight I found my brake master cylinder reservoir was low, and after a little bit of looking I surmised there was brake fluid coming out of the pdwa switch. It is an early car - 1971. Does anyone know who can supply a rebuild kit for the actuator?
Thanks a lot! Pete
PeterK
If it's leaking at the PDWA, it's either:
1 - one or more of the 4 brake lines that need to be tightened.
2 - the fiber washer at the end of the PDWA,
3 - the fiber washer under the switch, or
4 - through the switch itself (unlikely) or it might be loose.
Internally, there are two rubber o-rings, but they won't leak outside of the housing.
The fiber washers are easily replaced.
Try to locate the source of the leak but AFAIK, there is no kit available that contains the washers as they are a common item. The switch is available from the big 3.
It is more common that the reason for a low fluid reservoir on a 6 is an internal leak between the m/c and the servo diaphram. But since you say that you see an external leak, check the above.
TR3driver
Great Pumpkin - R.I.P
I don't know the change point offhand, but Nelson Riedel wrote that there was an early and late PDWA used on the TR6. Early seals are NLA, but the later units take ordinary EPDM O-rings. He made a replacement piston for his PDWA.
PM me your email addy, if you would like a copy of the article; or perhaps someone can post a link.
SpannerMan
SpannerMan
Don't you think that if one of the internal o-ring's goes, fluid is going to make its way out of the housing via the switch? The switch socket is basically filled up with brake fluid. The master cylinder is pretty new. In my experience, when that goes some of the fluid makes it into the driver's footwell.
RobT
Yes, the switch does not make a seal, and could never hold up against the hydraulic pressure if the internal o-rings go.
I replaced the whole unit on my TR250 with a new later model version. Not cheap. Even Apple would not do a rebuild. Alternatively you could just plug the switch hole and run without it. This unit is intended to signal a failure in one of the break circuits, but you should notice this through the pedal before the idiot light would tell you.
TR6oldtimer
I had a leak that was through the switch. One of the o-rings gave out, and out came the brake fluid. Re-paint time.
Here is the link to the Wiki Triumph page that will take you to the Buckeye article previously referenced.
https://www.britishcarforum.com/tikiwiki/tiki-index.php?page=Triumph
ALLAN
Has/is there been a definitive answer about these valve being just a safety valve or do they act as a proportioning valve also?---While Im waiting for a new switch to come in, I pulled the inside valve out and have been using the brakes that way and I seem to have more solid and even braking. But I still lean towards it also being a proportioning valve, because without the insides both front and rear of the Master are going to both front and rear brakes. What are some thoughts on this?
RobT
I don't believe the PDWA switch does any proportioning. However you do not want to run it without the insides - you now only have a single-circuit braking system. Better to bypass the PDWA and just run seperate front/rear circuits.
Rob.
TR3driver
The PDWA does not impede the flow of fluid to either circuit, even when the piston is all the way to one side or the other. Thus it cannot act as a proportioning valve.
It could potentially act to some extent to equalize the pressure between the two sides, but I don't believe this happens in practice.
Andrew Mace
Re: Source for TR6 pressure switch [pdwa] rebuild
ALLAN said:
Has/is there been a definitive answer about these valve being just a safety valve or do they act as a proportioning valve also?...
Perhaps this will help; it's something I seem to end up posting various places every couple of years, and this is from a June 2002 posting to the Team.Net Triumphs list:
Pressure Differential Warning Actuator
"The P.D.W.A. is an 'inline' hydraulic valve through which both brake fluid lines are routed. The purpose of the device is to detect failure in either of the systems and to transmit, electrically, warning of the failure to a light on the facia."Triumph GT6/Vitesse 2 Litre Workshop Manual, p. 3.230.
Master Cylinder
"Application of pressure on the push rod moves the primary plunger up the cylinder bore and allows a spring loaded tipping valve to return to centre. The primary supply port is closed by the valve and further movement of the primary plunger results in hydraulic pressure being transmitted to the wheel cylinders of the front brakes. At the same time the pressure created acts in conjunction with the increasing force of the intermediate spring to overcome the stronger secondary spring, thus actuating the secondary plunger.
"Initial movement of the secondary plunger closes off the centre valve supply port and the hydraulic pressure is transmitted to the wheel cylinders of the rear brakes.
"In case of failure of either chamber or circuit, mechanical contact takes place within the cylinders and the remaining chamber builds up the normal pressure to operate the brakes that it controls." same manual, p. 3.226.
Any questions? /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
PeterK
It is a "warning actuator," thus it's purpose is to turn on the brake warning light if it detects a pressure differential change when one side of the circuit fails. As the inner valve moves to actuate the light, the failing circuit is blocked off so you retain the remaining circuit for braking. But it does not affect the proportioning of the front to rear balance, just turns on the light and the o-ring seals off the bad side.
ALLAN
All you guys are probably right and I should not be running without that valve, but it will go back in when I get the new switch. I got my old spare PDWA and I notice that the front plug goes in and restricts the front line opening by 50%--does that not do proportioning some how?---Rob I dont think you can run without the switch because that is what keeps the valve centered -- (except when there is a problem and the switch gets activated) this is why I took my valve out because I removed my bad switch and pluged the hole.
RobT
The brake pressure being equal in the front and rear circuits will keep the valve centered - if all is working correctly the master cylinder will produce equal preasure to the two circuits as it "shares" the same piston. The PDWA and switch just detects when the pressure is not equal (the unequal pressure pushes the PDWA piston one way or the other).
So if you take out the PDWA piston, instead of there being two seperate circuits for the front and rear brakes, they will now share the same fluid through the empty PDWA housing, and a failure of the rear circuit will cause there to be pressure loss to the front and visa-versa. One fault in the system and all your brakes are gone.
If you take out the entire PDWA, and connect the brake line from the front of the M/C directly to the lines for the rear brakes, and the line from the rear of the M/C directly to the front brakes, (you should just need two couplings in place of the PDWA) you will still have two seperate break circuits, and so a failure of one circuit will still leave you with either front or rear brakes. You just don't have the idiot light any more.
Hope that helps,
Rob.
ALLAN
Rob, that is a good explanation but I still dont think that valve will stay centered without the switch in place, any small fluctuation in pressure from the master circuits will eventually shift the valve to one side or the other and then there will be a failure as you explained.---------still the one question, what about that front plug that restricts 50% of the front line opening?, proportioning or not?
TR3driver
Actually, it doesn't even seal off the bad side. That tapered nose on the piston still allows fluid to flow into the side with less pressure (if the MC can still produce fluid). Thus, even if your rear brakes are badly out of adjustment (which can activate the PDWA), they still get pressure eventually.
Which is a good thing, since there are a lot of cars running around with the PDWA piston at one end and the wire just disconnected.
RobT
Not. There is no proportioning on the dual circuits. If all is running correctly they are at the same pressure. The shared piston in the M/C makes sure of this. When you put your foot on the break pedal, you are compressing the break fluid going to the front and rear circuits the same amount. If you had two seperate M/Cs for the front and rear connected to the break pedal (as some set-ups do - mostly for racing etc)then you need a proportioning valve of some type so that you can adjust the pressure to the different circuits. For race cars, this can even be adjusted during the race, as track conditions change.
Rob.
PeterK
Really good discussion guys!
I've toyed with the idea of using a dial type proportioning valve on the rear circuit and eliminating the PDWA on my 4A(converted to a TR6 m/c with servo and PDWA). That way I can add more rear bias on tight autocross courses to add a little rear steer with a punch of the pedal and twist of the steering.
We used to have a Formula 500 with a setup like that and it was a lot of fun on 180 degree turns! Of course, the F500 stayed nicely planted at the rear end coming out of the corners as long as you kept your foot into the throttle.
ALLAN
Rob.
Same pressure but with a restriction less volume which might have some effect on the proportioning?? (not trying to be argumentative, im just not completely sold on no proportioning)
----------I just got my switch in the mail from Moss, interestingly it is in a Ford package with Ford part number. I looked it up, it fits Mustangs 67-69 and some other Fords and Mercurys 67-72. Part number C8AZ-2B264-A it sells on the internet for $20. and is also supposed to be available at NAPA. I will put this info on a new post.
I TR6 TR6 retractable seat belt source? Triumph 10
I TR6 TR6 most common source of leaks into cockpit? Triumph 7
I TR6 Source for 69 TR6 headlight trim ring? Triumph 7
I TR6 rivets/bracket source for TR6 headlight rim? Triumph 5
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 Source for 69 TR6 decals? Triumph 1
I TR6 Good quality part source for TR6 carbs? Triumph 3
TR6oldtimer TR6 TR6 part source Triumph 5
I TR6 Source for TR6 lower left and right crash pads? Triumph 12
I TR6 69 TR6 wheel source? Triumph 1
T TR6 Best source for a TR6 high torque starter? Triumph 12
SpannerMan TR6 TR6 seat back webbing material source Triumph 7
I TR6 Source for good carb rebuid kit for TR6? Triumph 2
Brosky TR6 Local source for TR6 3-prong oil switch ? Triumph 24
R TR6 Help: Brake Part Source or …. ? Triumph 1
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Vacuum Source Austin Healey 4
W Best source for Bugeye front shocks Spridgets 3
B TR6 Source for Carmine Red Triumph 4
steveg TR6 Source for fuel line P-clip Triumph 17
Sarastro TR4/4A Source for good convertible-top snaps Triumph 6
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
M TR2/3/3A Identifying Rear Axle Leak Source Triumph 12
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Michael Oritt Tenax fastener source needed Austin Healey 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
R TR6 Body Parts Source, Upper Midwest Triumph 6
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
RAC68 Source - Metal Clips for securing Convertible Top and/or Seat Covers Austin Healey 11
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
S TR2/3/3A source for those little drain hoses Triumph 6
I TR6 Source for Elevator Bolts? Triumph 16
I TR6 Source for license plate light bracket? Triumph 5
steveg Excellent source for info on and rebushing of SU carbs Restoration & Tools 0
MikeAH100M Whitworth Source Austin Healey 8
Jim_Gruber Source for 3" cotter pins for bump rubber on BE Rear axle Spridgets 5
K Healey Blue Paint Source Austin Healey 30
D Body work finishing supplies source. Restoration & Tools 0
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
JPSmit DC Power source thoughts Restoration & Tools 11
B TR2/3/3A Locating source of oil leak Triumph 6
J Half round tube or D tube source ?? Restoration & Tools 2
HealeyDave TR2/3/3A TR3 Dash Cover Source Triumph 9
B New frame candidate or parts source? Austin Healey 12
S Bay Area source for 60 Sprite Roll Bar? Spridgets 6
Jim_Gruber Source for PosiDrive Screws Spridgets 7
R TR2/3/3A Source for rubber seal on A/M side curtains Triumph 4
