The ignition switch!
I'm betting the ignition wire at switch terminal is nearly non-existent. I guess 50+ years may have taken their toll. Only way to be sure will be to remove switch and steering lock from the dash.
This morning I noticed the car would actually start when I wiggled the ignition key in the lock. Kept dying, but at least would fire. Then to verify, I ran a jumper from the battery directly to the coil.
Pushed the starter button, engine fired immediately and continued idling. Still need to check timing, points, vacuum advance, etc. (couldn't do that when it wouldn't run ...)
After 3 weeks, a discovery!
T.
