Hi Bob,RobWarren said:Hi all,
a.. The rear oil flinger/scroll on the end of the crank has been running so close to the engine block that it has overheated and this is the cause of the failure of #6 big end bearing, ---- the scroll type oil flinger will be replaced with a Holden type rear main oil seal using a neoprene seal.
c.. The cylinder head was inspected and it was found that there are 5 bent inlet valves and 3 bent exhaust valves, these will be replaced and 12 new valve stem oil seals will be fitted as required. Bob
a.. is possible, especially if the mains were line bored & or proper attention was not paid to the thrower clearances. The suggested remedy should cure the problem.
c.. could be due to serious over revving the engine or more likely, the valve stem to guide clearance was too tight. I don't know which you have but bronze guides require more stem clearance than do iron guides. If in an iron cylinder head, I personally would use .002" clearance on iron guides & .003" clearance on bronze guides.
