Pay close attention to the pivot stud, lack of a better word to call it, that the clutch arm pivots on. The stock one is too short by about 3/8”. Best to install the bell housing without the trans attached and operate the clutch to be sure the clutch arm doesn’t dig into the bell housing.thanks for the info. Got the trans back and sorting last of the pieces for a go.
Costs?Or scrap the whole stock slave cylinder and throw-out bearing for a Tilton hi-performance full hydraulic system.
View attachment 51542View attachment 51543View attachment 51544
I just put a 3/16” washer under the original one and works good.The Tilton TO bearing looks like a great solution on an unlimited budget.
For almost free, I made a slightly longer stud to move the operating lever to the front of the opening.
Make sure you mock all this up by mounting the bellhousing sans transmission up to the engine and checking the operation. The length of the clutch pushrod also bears on this.
Some of these issues may have been resolved by Pete Delaney.
Some of it has to do with the relative thickness of the three different clutches.
... Once the clamping is released, there's no benefit to additional travel anyway, and theoretically, you could shift faster (well, de-clutch & clutch faster, we're still at the mercy of whatever gearbox is in use).
I agree that the later__diaphragm sprung__clutch covers (aka pressure plates) are an improvement over the Long-style actuator,
