I have a '60 BN7 that came with a Smitty Toyota gear box conversion. I have twice adapted cables to fit the speedometer drive on my car's gearbox, likely a W57, but that is speculative. I also have done a 3.5 differential conversion. The angle of approach for the speedometer cable is forces a tight bend, and I think that has contributed to the speedometer needle hop I have experienced with the two different-length cables I've tried. I'm wondering if a Toyota angle drive might solve the problem. And I'll add that I don't find these for sale on eBay. Has anyone found a source for these units, is there any gearing issue involved, and what might either a new or used drive cost? As mentioned at the outset,I have successfully attached the Toyota drive fitting to a standard Healey cable and assume that piece fits into the angle drive????
Hi Guest!
