davester
Well disconnecting and putting the lines in the sun won't work for me. The lines are still in the car (plus they're hooked up to the pressure failure switch body). I wonder if the alcohol flushin is truly necessary, or whether it could cause trouble if I didn't get all the alcohol out. Any ideas or opinions? Also, did you just use isopropyl?
