side vents
maxwedge5281
i am considering adding side vents...ralleye louvers... to my v8 healey. i have reviewed several threads but still have a couple of questions? what is the best source...stateside if possible...for the correct sized vents? also, do the vents have a flange to weld in place or are they just butt welded and then ground down and the edge finished? i reviews steves installation and it appeared that his reworked vents did have a flange to weld to... thanks for any help...
A guy in Birmingham, Al made several sets years ago. I was lucky to get a set. His had flanges. I traced the outline of them on cardboard and placed cardboard on fender to where I wanted them. Cut and weld from there. I was a bit nervous to cut good fenders.
marv
rjc157
Get the ones with the flanges I think moss sells them IMAG0092.jpg did mine some 20 yrs ago they might have been from kilmartin.There was an article in the chatter mag some yrs ago i'll see if I can find it,also there are quality issues with the vents when I was looking their not all the same
Keoke
There was a member in our club with a V8 in his 3000 all he did was add a set of early Jaguar vents to his fenders. He said that took care of his heating problem and esthetically they looked nice too.
maxwedge5281
maxwedge5281
i inquired of moss motors and they have the vents flanged and unflanged! but they are alloy and of course my fenders are steel. the flanged appear to drop into with the flange on the outside of the fender and the non-flanged appear to be welded. it seems most of the cars i have looked at have the nonflanged vents. what am i missing and who makes these in steel? thanks for any insight...
Keoke
Probably Kilmartin?
John Turney
I have the Kilmartin vents from British Car Specialists. They have flanges. I brazed the flanges to the inside of the fenders and then used a small amount of filler to smooth the edge. Works great!
RA_Healey
I got the aluminum ones from AH Spares. They are steeped in on the inside which will clear the footwell.
I then made a wood buck template, practiced on a piece of sheetmetal.
Determined the location on the fender lining up the buck but also allowed a 1/2" overhang, marked it out and cut the fender.
Placed the buck on the inside of the fender, clamped with wood blocks on the outside and took a selection of hammers and hammered the metal over to form a flange. Trimmed it up, placed vent in place overiding the flange, drilled holes and eventually poprivited it in to place just like the factory had done.
maxwedge5281
maxwedge5281
could you provide a close up picture of the vent in place! thanks if you can!
CLEAH
Max, Have you looked at Steve Thomton's write up on how he did his Kilmartin side vents?
maxwedge5281
maxwedge5281
thanks for the responses. i ordered a set of steel vents this morning from healey surgeons. they are made by healey spares. i ordered the ones with the flange. as i understand it the flange mates up to the rear side of the fender and the flange is used to attach by welding. i thought that i would drill maybe quarter inch holes in the flange perimeter and spot weld and then finish the outer fender side edge. also a local body man suggested that they could be glued in place...any thoughts from the healey community and the best method! thanks
CLEAH
I've never had occasion to use the product, but I would think that the 3M body adhesive would be perfect for this application. That stuff is used to attach complete quarter panels, so a little vent would be no problem. Why run the risk of blowing a hole or distorting the sheet metal? I think the local body man made a good suggestion. Unless, as Steve Thomton mentions in his paper on the subject, forcing the fender back in place puts a lot of stress on it, causing the glued vent to pop off.
maxwedge5281
maxwedge5281
well i was going to go with steel vents. but, one of the forum members had a set of four aluminum fenders, hood, trunk and i bought those. so i guess i will use aluminum vents. does anyone know about the fit with the healey spares parts. i hope that i can mount the parts myself with final paint and fit by the local body guy....i would be interested in any thoughts or experiences with the aluminum parts. unfortunately the front fenders did not have the front vents already punched!.. thanks
John Turney
Get the aluminum parts to fit, then work on the vents. Replacement parts are notorious for not fitting without major work. It's not a question of quality parts, stories are told there was lots of variation at the factory. Once everything fits, I would go with RA-Healey's buck and pop-rivet method.
maxwedge5281
maxwedge5281
seems most of the vents are installed and attached from the back side of the fender. i have seen a couple of pics with the flange on the outside which is not as finished looking but certainly much simplier and perhaps not requiring the fender to be repainted after installation... comments???
HealeyPassion Works Rally Side Vents Austin Healey 24
B Side vents Austin Healey 4
AUSMHLY Works rally side vents...more than meets the eye Austin Healey 18
v8mgbal Side vents Spridgets 4
HealeyPassion Works side vents project paper Austin Healey 13
R Side vents Austin Healey 7
K TR2/3/3A Side view mirrors again Triumph 8
roscoe Side Curtain Hardware Austin Healey 2
G Right-Side Shock Weeping Oil Austin Healey 1
Walter74 AH Spares Side Exhaust Austin Healey 2
R MGB side chrome installation MG 4
W Need advice on installing new side curtain glass Spridgets 1
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
kodpkd Side Curtain Windows Austin Healey 11
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
D Rear Seat Side Panels, BT7 Austin Healey 3
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
D BT7 Rear Side Panels Austin Healey 0
T MGA Unknow side screen MG 6
K TR2/3/3A "Clip on" style side mirror? Triumph 9
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
S For Sale Side Screen Anchor Plates Triumph Classifieds 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
TR6Canuck TR6 TR6 waist seal clips - which side goes on which part? Triumph 6
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
R Grounding Side Lights Austin Healey 4
R bugeye side lights. Spridgets 0
R side light install Spridgets 2
HealeyRick BJ7 Side Window Alignment Austin Healey 31
Fanch00 Noisy Side Screens Austin Healey 13
Neil Z For Sale MG TC NORS Convertible top and Side Curtains MG Classifieds 0
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
madhouse 100-Six Side Curtains Austin Healey 8
R MGA MGA Headrest fairing for R/H side MG 0
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
S TR2/3/3A foot well driver side carpet Triumph 3
K TR2/3/3A Passenger side fender mirror....... Triumph 13
P TR2/3/3A tr3 side curtains Triumph 4
Healey Nut Side Screens Austin Healey 12
R Wanted 100 side curtains Austin Healey Classifieds 9
C MGA Side curtain info MG 11
S Wanted Side Curtain Retainer for Swallow Doretti Other British Classifieds 0
Sopwith_Camel MGB wirers are greener on the other side? MG 4
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
Got_All_4 TR6 Differential side hub measurement Triumph 1
