As I continue to do the little fixes on my 1962 MGA I run into small projects that I am sure someone has done before and has an answer to my questions. Today I am replacing the rubber on the side curtains. What is the best way to put the long strip of rubber into the frame. Should I put soapy water in the channel and pull it through the slot or should I try to work it into the channel a bit at a time with a flat screwdriver? Or, is there another way I should try?
Thanks,
Charlie
Oriental, NC
Thanks,
Charlie
Oriental, NC
