Shift Levers for Datsun 210 5 speeds????
twas_brillig
Much to my embarrassment and frustatrion: it appears that I've got
a - two Bug-eye Sprites
b - one fully functional Sprite smooth case transmission
c - two Datsun 210 5 speed transmissions
d - two Rivergate conversion kits
e - one (1) Sprite shift lever
f - zero (0) Datsun shift levers
g - miscellaneous Sprite transmisson parts, but no additional shift levers for Sprites or Datsuns
If you've got a Datusn 210 shift lever from a 4 speed or a 5 speed (Rivergate advises that they are the same), kindly send a PM.
I picked up the two Datsun 5 speeds over the years and was out it in the garage tonight, but no gol-danged shift levers! Frustration! Embarrassment! Rivergate has advised that they might be getting some in, and that the 4 speed lever works just find, but....
Thanks,
Doug
mrsprite
I have one, but it is missing the plastic bushing on the transmission end. I'll see if I can dig it up for you (it's buried in a box somewhere).
BTW....the 4 speed levers are the came as the 5-sp ones.....I had two side by side and they are identical.
JPSmit
well of course they are the same on the sides, but where you really need to check is the ends. One should have a little more more length to the right (or the left if it is upside down) to allow for the extra gear.
:jester:
Westfield_XI
The 3 plastic bushings are still available new from Nissan. There are 2 for the through bolt and one cup-like bushing on the very end of the shifter.
AngliaGT
I have two '78 Datsun B210's - 4speed,& 5 speed.
The shifters are different from each other.
- Doug
T
twas_brillig
Good Grief! All these years, I'd assumed that the Japanase manufacturers weren't as 'interesting' in their mixing and matching of parts as Ye Olde Brits! Another dream shattered....
Mr Sprite - I'd appreciate anything you could find; thanks for the bushing info, Westfield XI - that's really good to know. And thanks for raising my level of confusion Doug!
Later,
Doug
RickB
Later,
Doug
Heh - who do you think they learned it from???
My two shift levers are different in that the one in my car is cut down to about 6 or 7 inches long and the one that came with my 5 speed is about twice as long.
The 4 speed shift lever (the short one) seems identical on the business end, and it fit well on both transmissions.
My 5 speed tranny is the Dogleg version but it had the big "60" on the side, Paul A. says it was only made for one model year.
Gotta get that thing rebuilt and put in the car!
lbc_newbie
"My 5 speed tranny is the Dogleg version but it had the big "60" on the side, Paul A. says it was only made for one model year.
Gotta get that thing rebuilt and put in the car!"
Yo, Rick...let's do a mini NODoody and get both 5 speeds installed when you're ready. Maybe this spring? I just purchased one from the Spridget list.
RickB
Sweet - so you got that one - I saw Bill was asking about it, glad you got it!!
Mine needs a serious rebuild. I hope Paul A. can fit it into his schedule - maybe next month. For the short time I had it in my car it sure was nice.
5th gear on the freeway was like heaven!
T
twas_brillig
I've bought two rebuild kits from Rivergate, and The Young Chap helping/doing most of the work has rebuilt one of the transmissions and will hopefully pop by next week and do the other one. He had to take a couple of pieces to a shop to get them pressed apart, plus had a lot of frustration with keeping things lined up to install the tail piece. I'll catch up with him in the new year and flesh these comments out a bit.
Doug
RickB
oh - had not thought of this! Good call Kellysguy!
AngliaGT
I just checked - the 5speed shifter is longer from
the pivot point to the end that goes into the trans,but
is shorter from the pivot point to the shift knob.
I hope this helps.
- Doug
T
twas_brillig
I called a local Nissan dealer today and the parts guy promised to go into their archived material and give me a call back once he's got a part number and been able to check. When he calls (touch wood), I'll ask if he can advise if the lever is common with any other Datsuns. The Young Chap Helping reminded me that the three plastic bushings that the lever requires came with the Rivergate rebuild kit.
Doug
Westfield_XI
Doug
They weren't included when I bought my kit from them a few years ago. Good to see they are now part of the basic kit.
CraigZ
Friend of mine has that tranny (and a Nissan 1600) in his Midget. He had to cut the tranny tunnel to get it in - it's too fat. But with that engine the car goes like stink...
lbc_newbie
So you're telling me I need to modify my tunnel to get this dogleg tranny in? That's not cool..... I was hoping for a straight swap with my Datsun 4 speed. Did he have to modify it to fit because of the 1600 or because of the tranny?
RichBall
Ed
Datsun had two dog leg gearboxes around this time. The '79 210 used the 60 series dog leg and is a direcct swap with no cutting. the later 210 used the same gearbox but with the diffrent shift pattern. The earlier B210 and 510 used the 63a series and is wider and does require cutting to fit.
Check out the Rivergate website for a more complete description.
https://www.rivergate5speed.com/rivergate.html
Rich Ball
'76 Midget
Everett, WA
RickB
Mine required no 'adjustments' to the car at all.
Fit smoothly in without any cuts or changes.
RichBall Datsun shift levers on ebay Spridgets 0
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
S MGB 78 MGB cannot shift into reverse MG 3
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
S TR2/3/3A Gear shift knob Triumph 8
WHT Center-Shift Bellhousing Austin Healey 10
DrEntropy Shift rod seal in an automatic? Jaguar 7
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
C For Sale Brown Ebony Shift Knob Other British Classifieds 0
TomMull TR2/3/3A shift knob Triumph 19
J BN2 Shift Lever Bushing Replacement Austin Healey 6
J TR2/3/3A such strange thread on gear shift knob Triumph 12
D 62 center shift gearbox Austin Healey 11
AUSMHLY Wooden shift knob, how to refinish Austin Healey 35
RAC68 First Gear Shift Difficuties Austin Healey 3
D 1962 center shift gearbox cover Austin Healey 7
C TR2/3/3A Rotating shift lever Triumph 12
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
F Austin Side shift transmission question Austin Healey 0
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
HealeyRick 2=3 Shift Spridgets 9
C TR6 Shift lever Triumph 4
J BN2 shift bushing replacement Austin Healey 5
U Shift knob reference? Restoration & Tools 11
S 1962 BT7 transmission shift rail bumber in bell housing Austin Healey 1
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Shift lever issue [No Healey content] Austin Healey 0
S TR4/4A Fascia support and shift rod boot Triumph 0
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
wangdango BJ8 gear shift consol restoration... Austin Healey 9
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Zitch TR4/4A Who said the TR4 round shift knobs were NLA Triumph 4
Jim_Gruber Shift Points for Bugsys 948 w Cooper S Head Spridgets 3
tinman58 TR5/TR250 Funny sounds from gear shift Triumph 4
Rut 5 speed gear shift lever Spridgets 28
Rut MGB MGB OD gear shift lever MG 0
P Sprite Shift Lever Spridgets 20
T MGB My '80 B used to shift fine MG 2
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
