Shelley Jack for AH 3000
60TR3A
My mechanic has this old Shelley jack collecting dust and since I don't have a jack I thought I'd take it off his hands. Problem is, not only is it sans handle, it seems to be missing the top section. This is the jack he's willing to sell me for a very reasonable sum:
And here is a picture of what I think it should look like, though I'm certainly no expert so that's why I am asking you folks:
Assuming I'll need the top half of the gear, plus the handle, is there any resource you can point me to that sells old parts like this? I'm hoping to find what I need at The British Invasion in Stowe, VT next month as there is a corral of vendors selling all sorts of old bits and pieces.
You'll be very lucky to find the ratcheting handle w/o buying the whole jack. If you can get it a reasonable sum, grab it for parts but afraid you'll be sitting on it for a while.
Marv
60TR3A
60TR3A
So, assuming I don't opt to spend $400 to buy a correct Shelley jack, does anyone have a suggestion as to what new, inexpensive jack I can carry just in case I need to change a tire?
bighealeysource
Bronze
Hey 61TR3A,
Think a lot of owners carry a small sissors style jack in the boot. Can place it under the appropriate location and have room to actually slide it under versus small bottle jacks might be too tall.
Check out ebay, just search Shelley Jacks and there are usually several for sale. You need the Shelly jack with CA259 cast in the base, believe orange in color. I picked up the correct one for my 100M off of ebay but no handles - still looking for those.
Regards,
Mike
dphilippo
I wouldn't suggest using the original jack, those are good for concours, but not much else. They are pretty lousy to use and are often too tall to get under the car if you have a full flat. I would suggest going to Northern Tool or Harbor Freight and picking up their smallest scissor jack. They tuck very well in the trunk in the crevice under the back of the spare and actually work when you need them. I used mine about two months ago when I got a flat and it worked great.
Drew,
65 BJ8
60TR3A
60TR3A
Thanks, Mike. There is one on eBay that's already been bid up to over $300, but I'm not going to bother chasing after it. Too much money since I really just need a utility jack, not one for concours judging. It'd be nice if I could find the missing parts to complete the one my mechanic has as it is more correct, but as Marv said, chances of me finding those parts are pretty slim. Meanwhile, I'll pick up a small scissors jack and at least be able to change a tire in case of a flat and not have to wait for Hagerty roadside assistance.
https://www.ebay.com/itm/AUSTIN-HEALEY-30...r#ht_638wt_1065
The scissors jack will work good for the TR3 as well. I have a Shelley jack for my BJ8 but only for show. I carry a TR4/6 jack for it (also with the TR3). Grab the Shelley jack if its cheap, have it for show if nothing else.
Marv
60TR3A
60TR3A
Drew, do you think a 1-ton lift will be enough? That's the smallest they offer but the car is a bit heavier than that at around 2500# curb weight. The 1.5-ton model looks big: 17" long, so I'd rather go the smaller route.
60TR3A
60TR3A
I can get the incomplete Shelley jack for just $20. Even then, that's a lot of money for a doorstop.
Get it! I'll buy it from you for $25 if you don't want to keep it. 1 ton jack will be plenty strong unless you are trying to lift whole car at once.
Marv
Do yourself a HUGE favor: get a geared scissor jack. Even if the jack is rated for 2K pounds or more, it's very difficult to crank if not geared; I just found out the hard way on a recent road trip in my BJ8 when I needed to change the fuel pump (I prefer to remove the rear wheel). Even though you can turn an ungeared jack, it's (obviously) much harder and if you're not on a flat, hard surface it increases the risk you'll torque the jack wrong and possibly tip the jack.
Geared scissor jacks used to be common, but I think the main/only supplier may have discontinued them. I found a new one on eBay a while back, here's a used example:
https://tinyurl.com/9vdawbv
I now have one in both my Healey and my Mustang.
Unless you put the jack in the middle of the car, attempting to lift the entire 2500#, a 2kLb rated jack is more than enough to do the job.
I mean, generally speaking, if you're on the road, you're only trying to get a single tire off the ground...
Editor_Reid
Platinum
I'm not sure I'd pay anything for it. I've never seen parts for one, so it is extremely unlikely that you will ever find the missing piece. You'd have to buy a whole jack to get the part you need, so what's the point?
60TR3A
60TR3A
The operative word is 'doorstop'.
Keoke
Do yourself a HUGE favor: get a geared scissor jack. :iagree:
60TR3A
60TR3A
I've tried searching online for them and they don't seem to be offered anymore. I just need a jack in case of a flat, not for garage use. I haven't had a flat in decades so chances are I'll manage to lift the car using a regular scissor jack on the off chance I get a flat.
Precisely where you need a good jack. If you're on a soft, sloped shoulder, in the rain, with a wobbly car, cranking real hard on a jack that doesn't want to lift--the max rating is how much it'll hold, not necessarily how much it wants to lift--you'll wish you'd sprung for the geared one.
I got my second one from here:
https://tinyurl.com/8b72l5j
I offered $35, he countered with $37.50. Deal. Good seller.
Try your ungeared jack in the comfort of your garage, if you're happy with it, fine.
I use a floor jack in the garage.
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
T Shelley LJ21 Jack wanted Austin Healey 5
H Shelley LJ21 Jack 57 sell on Ebay for $647.53 Austin Healey 17
Johnny "Shelley" Jack on eBay Austin Healey 7
Bruce Bowker Shelley LJ 21 Jack Austin Healey 6
A Shelley jack information Austin Healey 1
P Spare Parts for Shelley Jacks Austin Healey 4
A Shelley jacks Other British Cars 0
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
roscoe Racing Jack Austin Healey 24
HealeyRick Perfect Healey Floor Jack Austin Healey 14
drooartz Bugeye jack points to remove rear axle Spridgets 18
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
JohnGone Wanted Spare & Jack for an '80 MGB MG Classifieds 0
R running car on jack stands Spridgets 16
jfarris TR2/3/3A Scissors Jack Triumph 5
60TR3A TR2/3/3A How To Jack Up a TR3A Triumph 14
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
nevets Testing OD with Car on Jack Stands Austin Healey 9
steveg Harbor Freight jack stand recall Austin Healey 7
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
S Securing the jack with strap in BJ8 boot Austin Healey 11
DerekJ Jack Rawles wins again!! Austin Healey 1
Sarastro TR4/4A Any ideas for repairing jack damage? Triumph 13
P Rolling jack bridge Restoration & Tools 8
DerekJ Jack Rawles Racing at Zandvoort. From 6th to 2nd. Austin Healey 4
DerekJ Jack Rawles - Spa 3 Hours in car video. Austin Healey 3
simon1966 Correct Jack for a 54 100? Austin Healey 5
R jack/jackstand placement bj7 Austin Healey 18
G Where can I get bottle jack seals? Restoration & Tools 2
S TR2/3/3A tr3 Jack, hub cap remover ect... Triumph 2
M Bugeye engine removal with floor jack Spridgets 14
I Bugeye jack handle Spridgets 4
R correct jack stand placement. Austin Healey 26
G MGB Placement of jack stands MG 4
Marvin Gruber Austin Healey Shelly LJ 21 Jack Austin Healey 0
pkmh Interesting little jack stand discovery, "Drednaut" Austin Healey 0
DNK I need a jack Restoration & Tools 37
R jack for BJ7 Austin Healey 9
bthompson In Praise of the Midget Jack. Spridgets 7
nevets Question about jack stands Austin Healey 11
J Floor Jack Recommendations Triumph 0
J Floor Jack Recommendations Restoration & Tools 15
JPSmit Is Jack around? Spridgets 1
H correct BJ8 jack Austin Healey 1
SilentUnicorn Floor jack rebuilding Restoration & Tools 18
J TR4/4A TR4A IRS Jack Stands Triumph 6
W A question for Jack Spridgets 11
CinneaghTR Preferred Jack and Jackstands for LBCs? Restoration & Tools 11
