Left hand (spiral) drill bits: best easy-outs there are. If they bite into the stub and back it out (friction creates heat) you're home free. If they don't, you still wind up back to the tap-drill size, and can run a tap to restore the original threads.
I could or in fact, I will, modify the bolt head to match my old one. There is even a method I could use to salvage the coding on the head of the old and fix to the new.
Gives me a chance to throw everyone off once in a while and I certainly have no need or desire to carry an extra tool kit in the car.
FWIW, I don't bother to even try to get them our with an easy out. I just keep drilling the hole bigger and bigger until the remaining wall of the bolt is so thin I can fold it in on itself like foil.
Finally posting photos as I wanted to and mentioned from my earlier post.
First photo shows the pilot mark I made before drilling in succession using various bits as also shown.
One photo not shown is how I decided to cut (actually grind)into not one, but two sides including the screwthreads. After all that plus applying flame and ice, the sheared remains of the stud still wouldn't come loose. That's when I drilled a 10mm opening (that's right, you heard me).
The last photo shows the modified 10mm hex bolt [head] compared to the standard 5/16" on the right. Both hex head dimensions are the same so only one tool kit is still needed (ha, ha).
Maybe one day I'll go back and cut out a section of the chassis flange like Randy Forbes displayed, but only if experiencing the same amount of corrosion.
But it seems my chassis is holding up (sorry, I had to clean and paint over--couldn't take seeing all that grime anymore).
