cpbol
There is no heat shield. The carbs were converted from 2 to 3 in 1969, and the cam and headers were changed. I can't see how there would be any room for a heat shield with the rear two bowls being so close to the manifold. Since I'm sure the bowls have always been there, I'm also sure that different fuels must have different boiling points. I just topped off the tank with 93 octane from Sunoco, and drove around for 20 minutes without a sputter. I think I've identified the problem; now it's just a matter of dialing in which fuel won't boil on me.
Recap on the symptoms (which now all fit together):
1. Car runs like a champ when cold.
2. After 7-10 minutes, it starts sputtering, hesitating, and losing power. It does NOT recover after driving for a while.
3. After a couple of short stops the sputter comes on soon there after (also comes on even if I don't stop and turn off the car for a minute).
4. After the car cools down for 15 minutes or so, it runs fine again.
5. I can hear the fuel pump working extra hard and pumping fast around the same time the sputtering occurs.
6. During a normal sputtering episode, I quickly removed all 3 float bowl lids and could visibly see bubbles coming from the bottom of the two rear bowls, which are located within 1/8" from the exhaust manifold. There is no heat shield installed (and has not been for 49 years.)
7. The fuel tank is clean.
8. New plugs, wires, coil, condenser, electronic ignition, OD dash switch, fuel filters, bowl seats, and fuel pump did NOT fix the problem. (at least I have a nice list going of what is working well!)
9. I have been running 100% gasoline, which is 87 octane and contains no ethanol. I have also been using lead additive.
10. After topping off the tank with pump 93 Sunoco, the car ran fine for 20 minutes and never started sputtering. After pulling into the garage and loosening the fuel line between the carbs, vaporized fuel escaped, indicating the fuel was starting to boil again.
I think I've about got it figured out if I can continue to validate that normal pump 93 fuel allows it to run okay. More testing to come!
I genuinely appreciate everyone's input. I hope others can learn from my frustrating ordeal!
