I have had a problem for several years and sure would like to solve it. Whenever I make a fairly sharp right turn at speeds between 35 and 55, the front end shakes violently. It does not shake at all on a left turn. Also I get the same shaking whenever I brake and am steering straight. I have noticed that if I have a heavy passenger (an adult), the shaking is less intense. I am about to replace the struts but don't anticipate that this will affect the shaking much as I have had them replaced several years ago and there was no affect on the shaking then. (I'm replacing them this time because they have failed). I raised the front end and checked the bearings (by shaking & twisting the wheels) and while there is some minor play, they seem to be ok, but I am not experienced in that area. If you have any suggestions, I would certainly appreciate it. This has been a nagging problem for a very long time. Thanks.
