TR4/4A Second gear hard to shift into on first try
Tony P
I have a newly rebuilt transmission on my TR 4. When I start the car, warm it up and drive off shifting from 1st to 2nd is difficult and I have to double clutch to get it into 2nd. Now here is the rub, once underway the gearbox works smoothly and quietly. After the very first shift to 2nd, all other shifts into 2nd are smooth. It only happens once and that is the first time out of the driveway.
I have installed new clutch, T O bearing, cross shaft bushings, pressure plate, clutch master cylinder, slave and hose. I have spent hours adjusting and readjusting the slave linkage per the car manual.
I can live with the one time double clutch per outing, but it is just driving me crazy when I can't seem to figure it out. What do you guys think?
Tony P
Darrell_Walker
What are you using for fluid in the transmission?
T
Tony P
Hey Darrell, I am using 80-90 wt. spiray oil I read on another thread that I can add a pint of some other oil to smooth it out. I will have to search it out and get back to you. Thanks.
Tony
T
Tony P
Ok Darrell, I found it. That person said to put a pint of Lucas oil treatment and then top off. He said he has gotten good results. Who knows. I have to research what is in that Lucas treatment and see if it will effect the trans.
sail
I had that problem when I rebuilt my own box. Scared the wits out of me. Mainly when cold and tests were in November/ December. I now just take it easy when cold and know thats the way it is. Redline helped, me being aware helped more.
bobh
I'm with Sail,
When I changed the oil in my TR6 last summer I went with Redline MT90. I don't know if the Lucas additive is rated. If so it needs to be GL4 not GL5. Personally I don't use any additives in the gearbox. I do run a few ounces of Redline Break In fluid in the engine to make sure it gets its Vitamin Z (ZDDP)
T
Tony P
Well redline MT 90 sounds like the ticket. I know that I have to do a fluid changeout on the Tr4 as soon as I reach my 1000 mile break in point on my engine rebuild. Still trying to get everything to settle in with my engine, carbs, trans and OD rebuilds. I guess miles is all that is needed for a while.
thanks for the help
Tony
alanjohnturner
Do you have OD?
In the UK where its basically cold and wet even in Summer lots of guys use engine oil in the gbox. Some do this with OD fitted.
The second gear syncro has a hard job to spin up the gear when the oil is cold. There is a lot of oil drag in these boxes.
When these were new we all used double-declutching most of the time. Lots of boxes had no syncro on first.
You may find this interesting:
https://www.quantumechanics.com/qm-htm/topic1.htm
CJD
Good article Alan. Sounds like 30W non detergent is the way to go. It also explains why the 140w I'm using in the non-overdrive box is so stiff when cold. That'll have to come out at the next change...
T
Tony P
Yes I do have OD and I am thinking of going to a lighter wt soon. I will start from 90 wt and reduce wt until I get the response I need on that 2nd gear shift. Thanks Alan.
Tony
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
O TR4/4A tr4 pops out of second gear on deceleration Triumph 13
S Issue with second gear slipping out... Austin Healey 12
J T-Series Clatter in second gear only? MG 1
W pops out of second gear on acceleration Austin Healey 12
L Popped out of second gear! Austin Healey 4
bthompson I've lost second gear!! Spridgets 95
T Argh! Jumping out of second gear now Triumph 10
T Flat. Stopped. First or second gear? Austin Healey 4
K Second gear grinding Triumph 17
S TR2/3/3A welders have a second Triumph 5
Basil Second Telluride Spotting at Costco Spotted 0
D Lilly second time running... or trying Austin Healey 8
GTP1960 Here's one worth a second look. Other Cars 1
gbtr6 TR6 Top Cover On, won't go into first or second Triumph 6
S TR2/3/3A Well onto the second half Triumph 2
I adding a second fuel pump Austin Healey 16
Basil Lotus and Jags second try Spotted 3
H second guessing myself-oil thrower question Austin Healey 2
M MGB Second MGB Off Production Line and First LH MGB [GHN3L/102] MG 3
Triumph_TR4_Girl TR4/4A Second Hand Copy of Original Triumph TR4 Triumph 1
B Second picture. I don't quite get this yet Triumph 1
N What to buy, second try MG 26
K Second hand spoked rims Triumph 18
W Second Motor, looking to rebuild it Triumph 16
tinman58 Second thing to check Triumph 14
L Difficult to engage second MG 4
R Need a Second Opinion Spridgets 17
Marvin Gruber XKE second opinon Jaguar 28
T TR6 Purchased a second TR6 Triumph 29
R My second crash and first in a car. Austin Healey 9
Sopwith_Camel from last summer my second to last day in norway Spridgets 8
JPSmit second verse same as the first [almost] Spridgets 13
Brosky eBay Hardtop, second go around Triumph 5
hondo402000 TR6 TR6 rebuilt the Front Calipers, second time Triumph 2
Dadandson My 1974 Midget took Second!! Spridgets 6
Brosky TR6 Second chance on Special Order white/blue TR6 Triumph 8
T Today's Second Stupid Question? Triumph 8
John_Mc Second boot lid Triumph 0
S Second blown head gasket in my Midget! Help? MG 21
P Second Time Around... Spridgets 2
drooartz High idle, second test Spridgets 3
simpzimmer Second Question British Motorbikes 6
RobT Second Failed Ignition Rotor in 100 miles???? Triumph 14
L Help!! wife says I'm in second childhood MG 5
J so i'm kinda having second thoughts about my car.. Austin Healey 29
J New lotus offshoot Vauxall version of elise with turbo pulls 4.5 second 0 to 60mph! Lotus 0
L T-Series Gear box servicing cap. MG 5
