Erica
It's a Moss 475-190 being fitted to the rear of my '77. The fit is good, going right to the bottom of the underlying metal. The fiberglass has a little flex. Only the middle mount had been fitted when the first photo was taken, but the gaps will disappear once the other four mounts are in place. The second photo shows the middle mount being securely attached and one of the other four mounts. The two side mounts are the same but will use the stock angle cut spacers (shown) instead of a nut, fender washer, body panel, fender washer, sandwich.
Erica
Erica
