SaxMan's Winter 2014/15 Project Thread
Nice! But, take her out with the top down! that's why we have hats and scarves - and I promise you will get more waves and smiles than any day in the summer! (and it is all kinds of fun)
Boy, JP, you weren't kidding! My daughter and I bundled up and took the car out...top down. It was in the mid-40s. To be honest, it was no worse for me than riding a bike in similar conditions. And, yes, we got more honks and waves on a relatively short loop than I have on far longer drives in the summer.
The car drove well. I think the mixture is a bit off again, but that's probably a weather-related issue. Also when I turned on the headlights, they went direct to high-beam, and pulling back on the high beam stalk did nothing. I'm pretty sure that's a case of getting my wires scrambled on the headlight switch. Other than that, I was very happy with how the car performed. Again, with the vacuum line from distributor to carb replaced (and not leaking), the car's idle was smoother than I've ever had it before.
EDIT: When I went to go troubleshoot tonight, the high beams worked properly. I think the car was on low beams, but sometimes during the day, it's tough to tell. Sometimes I feel like the Randy Quaid character in Christmas Vacation "Gets kicked in the head, eyes crossed. Gets kicked in the head again, eyes uncrossed. Go figure."
woo hoo! an LBC in its natural habitat! any pics?
No pics, unfortunately. I wanted to, but it started to precipitate, so I figured I'd make a beeline for home.
Started working on the other rust spot tonight just behind the right front wheel. When I began sanding, and grinding, I tripped across an old Bondo fix, which exposed some smallish holes in the metal. It was a bit disappointing, but certainly not surprising. So...old Bondo out, new Bondo in. I actually learned how to work with Bondo while restoring the TBM Avenger, as we were trying to smooth out some of the divots in the plane's skin, particularly on the wings and tail surfaces, without having to resort to reskinning...but I digress. I put the "mud" on and worked it in. I figured I'd go ahead and let it harden completely overnight before I start sanding and smoothing it out. I completely forgot how much this stuff smells! Worse than paint!
Good to see your making excellent progress. However, the problem with bondo is that it absorbs moisture. If you are covering holes in the metal, then the back side of the repair must be sealed with paint as well. Otherwise, the bondo causes the metal to rust faster than an open hole.
Some more pics of the exterior repairs:
The cursed rust bubbles "in bloom" on the left rear wheel arch
DSC_1801 by onyxsax, on Flickr
Rust bubbles behind right front wheel:
DSC_1806 by onyxsax, on Flickr
Rust grinded off. I learned that rust bubbles also burrow into the metal. On this repair, I didn't fill the holes.
DSC_1808 by onyxsax, on Flickr
Masked, primed and painted:
DSC_1818 by onyxsax, on Flickr
While waiting between coats, I was doing a more thorough detailing of the interior:
DSC_1830 by onyxsax, on Flickr
Interior from passenger side:
DSC_1832 by onyxsax, on Flickr
Masking off the area on behind the right front wheel:
DSC_1836 by onyxsax, on Flickr
The old bondo repair covered the holes near the "V" of the tape mask.
DSC_1838 by onyxsax, on Flickr
New bondo slopped on. I learned a valuable lesson -- remove the masking BEFORE the bondo hardens.
DSC_1841 by onyxsax, on Flickr
Left wheel repair clear coated. I still have to hit it with some polishing compound to smooth it out. It's not a perfect match, and up close it is undoubtedly an amateur repair. I'm not too pressed, as there is definitely a learning curve with body work. I'll live with it for this season and redo it next winter.
DSC_1842 by onyxsax, on Flickr
Finished the rust repair on the right side. I learned that trying to cover an area more than a couple of square inches with just a touch up brush is a futile gesture. I'll probably have to go back and hit it with a rattlecan when the weather gets warmer. I need to do some rust remediation in the trunk, so I'll probably hit the area again when I do that work.
Home stretch: Time for a wash, hit the car with polishing compound and then a coat of wax.
Time for some more pics to catch up:
Finished sewing up the steering wheel:
DSC_1709 by onyxsax, on Flickr
Steering wheel back where it belongs:
I think you might find your steering wheel cover to be more comfortable on your hands if you lace it like this:
Rick, I am not visualizing the lacing parts of that - the pieces do overlap don't they. (should we start a new thread?)
Thanks, Rick for the tip. I'm probably going to leave it as is for now, but will change it if I have to replace again. It's perfectly comfortable for my hands.
The headrests came back from the upholstery shop. They did one heck of a job with them. Better than original if I must say.
Rick, would there be two or three open thread holes where the spokes attach to the wheel? Not sure where the thread comes back up form behing\d the wheel
Been a long time since I did this one, so the memory is a little hazy. There are two open thread holes around the spokes on the front. At the rear, the thread runs with the rim in order to get around the spoke. There may have been a way to run the thread around the front if having the holes in the front were a concern:
I installed the headrests tonight, and other than some minor tweaking and tuning, the winter project has drawn to a close. I got a pretty fair amount done:
Reconditioned seat frames and hardware
Installed new foams
Installed new upholstery covers
Upgraded dashboard lighting to LED
Installed new choke cable
Recovered steering wheel
Installed new plug for U-Joint Access (and greased U-Joint)
Replaced brake pedal and clutch pedal pads
Replaced heater core return line
Replaced fuel tank
Change all fluids
Compression and leakdown testing of all four cylinders
Replace valve cover gasket
Adjust Valves
Replace vacuum line from distributor to carbs
Replace spark plug wires
Replace cap and rotor
Install new spark plugs
Oil & Filter Change
Added damper oil to carb dashpots
Rotate tires
Rust repairs on left rear wheel arch and right front fender
Touch up other chips and scratches
Detail interior
Exterior detailing including polishing compound and waxing
It took me a total of 62 man hours spread out over 47 separate nights in the garage to do all of this, not including time spent ordering parts. I did all the labor except for recovering the headrests, which were farmed out. Hard to believe that it's only been about 18 months since I first started on the LBC adventure. Thanks for all of your support during the process!
I spent about an hour taking the seats out of my BGT... boy do I feel extra lazy now. :grin:
Well done, well done indeed!
Aw, shucks, JP.
The garage is my sanctuary. I go there to get away from the stresses of everyday life. There's something (usually) relaxing about taking things apart and putting them back together again (and hopefully putting them back together better than when they were first taken apart!). With the car basically done, now it's time to tend to the bicycles.
I feel the same way - I put on the radio and just putter. Wish the garage was a little warmer, but, my little heater mostly does the job. That said, still an impressive list!
One of the "odds and ends" that I took care of tonight was replacing the accelerator pedal. Like the seats, it was bolted through the bottom of the car, so to loosen the bolts took quite a bit of contorting my body -- impact wrench up top, crescent wrench below. But, I did get the pedal off and discovered the hinge was so dry and rusty that the pedal wasn't moving freely. Replacing the pedal took the same amount of contorting. The end result was another "wow". The new pedal feels so much better and responsive. I still have to watch my right foot when going to the brake to make sure I don't accelerate at the same time, but by now, I've learned how to do the "Spridget Shuffle" with my feet. Out of habit, I now work the pedals the same way in my Jetta, even though I have a lot more clearance between the pedals.
One of the other habits I have as a cyclist who uses clipless pedals is that sometimes I try to "unclip" my foot from the accelerator pedal, even though my shoes do not have the cleat, nor does the pedal engage like a bicycle.
