jlaird
Rear carb leaked from the bottom of the float chamber where is attaches to carb body. A unique bolt and two rubber thingees and one metal washer there, the bolt will only allow you to tighten so much as it has a lip to prevent it going in further.
Fix, double up on the metal washer, alows you to get a bit more on the bolt and squeeze those rubber seals a bit more.
There is no excuse for leaks except from the rear of the engine and that can not be helped if mains are undersize.
