philman
Wife's car decided not to start anymore. Saab 9000 w/3.0lv6 (same engine as a Saturn). This is a sudden failure. Engine turns over, timing light sees sparks at all plugs, fuel rail has 40lbs pressure. Timing belt is intact and turns over with starter.
No tach movement. Does this indicate the cam position sensor is bad? I get a 0.2 vac signal off the CamPS when the engine turns over. But I don't know how much is needed for a "good" signal from the
Thanks in advance if you have any ideas.
