I purchased a 1976 TR6 last Spring. The owner told me he had a "S2" cam installed. He had also installed a Pertronix ignition. I have installed twin Weber MCHH carbs.
I can no longer reach the seller as he now lives outside the USA and the old email address doesn't work.
My Question is: what valve clearence/s should I use? I failed to check clearances before I had a mechanic work on the car so they are presently set to factory specs for a factory standard cam.
