I have had two weekends in a row where I actually just drove the TR3. I got in, turned the key, pushed the starter, and drove around! No work of any kind (OK, I tinkered a little). Of course, I am knocking on my wood desk as a type!
I do have a question, however, about the correct running temperature. As you all probably know, it gets pretty hot here in Austin, and the temperatures are starting to climb. Today was in the mid 80's while I took a 30+ mile drive. The temperature reading was a little above the 185 mark, which is dead center in the gauge (I assume this is a standard gauge). For a period of time, I was going 65-70mph (with Overdrive engaged) and the temp climbed a bit (although it never reached the next line on the gauge). After that, I spent a few miles on a side road going 40-45 miles per hour and the temp dropped a bit, but was still a bit above the 185.
I think this sounds pretty good, but I have read on this forum and others that the car should not run above 185. I am wondering if everyone thinks this sounds OK. I am about to enter into a hot part of the year and my eye will probably spend as much time on the temp gauge as it does on the road.
For your information, I do not have an electric fan. When my father had the car, it was removed when he upgraded to one of the better water pumps, and it actually ran cooler without it.
Thanks for your input.
