Stan '75
Thanks to everyone who assisted with getting my replacement fuel pump installed and connected. I've replaced the fuel filter and confirmed fuel is getting to the carbs. Starting with the metering needles at 1 1/4 turns off lean, I could not get the engine to stay fired. Moving 1/2 turn clockwise (lean), the engine will run extremely rough for 4-5 minutes. It will immediately stall if I attempt to add any throttle. I dialed the needles clockwise (lean) until they stop and while the engine improves slightly, it still will not stay running with any additional throttle. It also will not start with any choke. My idle rpm is around 250 and any attempt to adjust the idle screw causes the engine to stall. I cannot adjust any more lean and am out of ideas. Have I supplied enough data for your thoughts? Thanks in advance!
