Stan '75
I have not, but excellent next step. I completed the carb work and still can't get it to fire more than 1-2 times.Stan, not to go against the carbs conversation, but have you looked at the timing yet?
PDIGIO, thanks for the timing tip. Once I had the carbs completed and installed, I loosened the distributor and manually adjusted. The engine fired and started. Now that I'm running, it's time to through a light on it and dial things in. I appreciate the help!Stan, not to go against the carbs conversation, but have you looked at the timing yet?
