General Tech Running hot
Trevor Triumph
I replaced the radiator - and the engine gets to the "N", the midpoint of the needles's sweep. At idle at a traffic light of stop sign the needle moves toward the hot end of the sweep. Usually, the needle returns to the normal position after a short distance. Lately it seems to take more time. I have not adjusted the SUs in a while, and I understand if the fuel mixture is lean, the engine tends to run hotter. Also the number one cylinder has about 70 psi, the others are 110 psi. Also there is a the sound of exhaust leak. I tightened the manifold bolys to spec and it sort of cleared up. I was teaching grandkids to drive the car and the temp gauge went into the "hot" zone. I immedialtely took over and drove home the and needle returned to normal range. The "leaky" exhaust sound has returned. So... Warped head due to lean mixture / mis-adjusted SUs, timing problem?
T.T.
NutmegCT
What's the weather like when that overheating happens? Southern Arizona isn't known for a cool dry climate.
I'd bet a thermostat controlled electric fan would do what you need. Also, are the coolant passages through the engine clean, or full of 60 years of crud?
Hope this helps.
Tom M.
Graham H
Not likely to be a warped head due to a lean mixture but it could be a blown head gasket, run it with the radiator cap off and look for bubbles in the water.
Graham
Mickey Richaud
Graham
Yeah, with that low compression reading on #1 it sure is a possibility. How does the oil appear - any milkiness to it?
bobhustead
Mixture is not causing this. The number 1 cylinder is probably involved. Can you find a shop with an exhaust gas sniffer for the radiator?
Sarastro
Since you replaced the radiator, I presume you have replaced the coolant also. But there still could be rust and crud in the block. It might be a good idea to do a full flush, with stuff designed for that. I've used the Prestone in the past, and it removed a lot of crud, but there are others.
Also, as with any cooling-system problem, replace the thermostat.
Finally, there should be an orifice in the bypass line, usually where the bypass line connects to the pump. Some older TR water-pump bodies don't have one, and without it you can lose a lot of cooling capability.
I agree that you could have a leaking head gasket, but I think that should be second to making sure that the cooling system itself is doing its job.
CJD
The TR cooling system is airflow limited. The stock fan does not provide enough flow to cool when at a stop. The solutions are:
1) Check the ducting is installed properly from the cowl to the radiator.
2) switch to a "tropical" fan, which moves more air.
3) Add an electric fan, which will absolutely solve your problem, but it requires more power, so an alternator conversion is also required for this.
Here in 100 degree Texas, I simply shut down the motor if I am at a long stop light. It fires up instantly, and as long as the car is moving it has enough air to stay cool.
T
Trevor Triumph
Thanks for the suggestions.
I checked the radiator cap; sometimes the rubber is crazed so pressure can't build. It seemed to be smotth and pliable.
A friend uses the eight blade fan from a later Spitfire - his suggestion.
I'm not sure, but the thermostat could be malfunctioning - I think I replaced it when we rebuilt the engine in 2007.
I get the opinion is there may have two problems, perhaps unrelated - the cooling system and low compression.
T.T.
Graham H
A leaking head gasket will give you both problems, I had a similar problem because I didn't retorque the head after my rebuild, I think it may be head off.
Graham
sparkydave Trouble running hot Spridgets 10
Bob_Spidell Running hot/Overheating Austin Healey 44
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
I TR6 TR6 enine running hot - need some adivce Triumph 40
W running way too hot. Triumph 34
tinman58 TR2/3/3A TR3 running HOT Triumph 38
martx-5 TR2/3/3A TR3 Running Hot Triumph 15
T Running hot Triumph 7
VelodromeRacer Running engine hot...? Racing 6
bluemiata90 REBUILT ENGINE START-UP......RUNNING HOT Triumph 14
boeingpilot TR4/4A TR4A Is it really running that hot!?! Triumph 19
Ed_K If your car is running hot, get one of these ! Austin Healey 5
GT6_Mark Hot Running Problem – Twin Stromberg Triumph 16
S Spitfire Spitfire running hot Triumph 10
R Wedge TR8 running hot Triumph 11
R Running Hot Triumph 9
jaybird B's running a tad hot MG 7
Stewart B's running very hot MG 21
R running a little hot? Other British Cars 7
gsalt57tr3 running hot Triumph 16
Steve P. MGB-GT Help:'70 MGB-GT running hot MG 4
Kim de B Running too hot up grades at speed MG 28
Mickey Richaud TR2/3/3A TR3 Running Hot Triumph 18
K TR2/3/3A What are the running symptoms........ Triumph 21
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
