jsneddon
Some people love-em but I don't find the ColorTune to be the "magic tune-up pill" that you'd think they are. I'm more of a fan of lifting the piston a 1/16th and listening to the engine speed. But you've got to get the valves set and the timing close first before you mess with the carbs. I _DO_ like the unisyn though (the thing with the red bead you were talking about)...
Here's carb tuning in a nutshell:
•Same Fuel: Set Carb float height to 7/16 (for TR - check your setting for MG) This makes a much bigger difference on mixture than you'd think. The float assy is a toilet bowl. Too high and you're spilling more fuel into the jets and you'll never get it lean enough.
•Same Air: Balance Air flow with carb linkage separated
•Mixture – 12 flats down to start. Lift Dashpot:
- RPMS Rise = too rich
- RPMS Drop = too lean
- RPMS Rise Briefly and then fall back = Good Mixture
