I've seen those cam and dizzy shaft gears worn to razor blade thickness, Jack. It can happen.
Vince, you're likely feeling the mechanical advance mechanism. It *should* spring back to a "zero" advance position on it's own. If it doesn't, you could have weak or missing springs. And perhaps have found your run-on cause. I'm not gonna hold me breath, tho... /ubbthreads/images/graemlins/grin.gif
